https://www.pistonheads.com/gassing/topic.asp?t=135334 píše:1. Park the car and apply handbrake.
2. Chock the front wheels (in my case against a kerb in a parking space at home).
3. Start the engine, depress clutch and engage 5th gear.
4. Rev the engine to 2000rpm and then slowly let the clutch out until you feel it start to bite.
5. Let the clutch out until the revs drop by 500rpm and then hold it steady for about 90secs.
6. I then repeated the process twice more but only for 30seconds each time.
7. I then let it cool for a few minutes, then did it one final time more for 1 minute.
8. Switch off engine and leave to cool (I left it overnight).
ok2ucx píše:1. zaparkovat + ruční brzda
2. bezpečně zablokovat přední kola o "něco" pevného
3. nastartovat, zahřát motor a zařadit 5ku
4. otáčky na 2000rpm a pouštět spojku až začne lehce zabírat ("zakusovat")
5. pouštět spojku dále, aby otáčky klesly na 500rpm a tohle vydržet 90 sekund
6. zopakovat ještě 2x, ale pouze na 30 sekund
7. nechat vychladnout na pár minut a pak poslední pokus na 60 sekund (to musí být peklo)
8. nakonec nechat zcela (např. přes noc) vychladnout
Bulletin#: 05-002/02
Last Issued: 03/18/2002
Subject: Clutch Chatter During Cold Start
Applicable Model(s)/VINS: 2001-2002 Miata with manual transmissions built prior to 12/01/2001
VIN Range: JM1NB353*10000001-20223944
Description: Some vehicles may exhibit clutch chatter or judder when releasing the clutch during cold conditions. This may be caused by the flywheel and clutch cover surface materials creating a chatter or judder during clutch engagement. The flywheel and clutch cover has been revised to correct this problem.
They go on to describe the REPAIR PROCEDURE
Here is the list of parts:
Clutch cover = BP11-16-410A-9U
Flywheel = BPR7-11-500A
Clutch Disc = BP07-16-460C-9U
Warranty Info: This info applies to verified customer complaints on vehicles covered under normal warranty.
Uživatelé procházející toto fórum: Google Adsense [Bot], Seznam a 11 návštevníků
